For the main bores in the body, is conctricity critical? I think one of the bores is going to be from the back, I can certainly center it in the 4jaw, just checking if I need to hold tight tolerance for it.
It isn't particularly important, a few thou Esther way is going to be fine. The rear bore is for the bearing, which is the only fixture holding the bit "centered". I intentionally did that to try to give us a little wiggle room in getting the offset right.For the main bores in the body, is conctricity critical? I think one of the bores is going to be from the back, I can certainly center it in the 4jaw, just checking if I need to hold tight tolerance for it.
I designed this like _I_ was making it, so there is basically 1-2 important dimensions on everything at mostCool. That helps. I would like to keep everything as close as possible, but there's always tolerance somewhere.
Did I get the only to "important dimensions"? Those bit have got to be a bit an the unforgiving side!I designed this like _I_ was making it, so there is basically 1-2 important dimensions on everything at most
I had figured you would use a sine bar to set the angle, it should be pretty straight forward I'd you have one. I've not considered what doing a angle gauge would do...I feel like I should be knocking these out now, but now that I have he ops down, its only a few hours work. I did measure the angle with a digital angle gauge of the "prototype" plate I made. I actually have (not the thickness) an angle of 89* and when I flipped it...91* but now I'm perplexed. Do I run at the .045" imbalance I purposely used or do I drop it down to .042" as planned. I can always remake mine real quick so I'll keep mine as is and we'll all compare notes I guess.
What steel did you use @ttabbal ?
Each part has a couple.Did I get the only to "important dimensions"? Those bit have got to be a bit an the unforgiving side!
