- Apr 4, 2016
- 853
You did good Bob.Ted knows more about HVAC than I ever will. Ted, is my description of how heat pumps work reasonable, if maybe a little clunky?
My response to the OP was pretty vague, so I should be a little more specific. First let me say that I'm not familiar with your climate so I base my suggestions on the climate where I live, where temperatures generally range from low 30 deg F temps to over 100 deg F. My suggestion for using an 18KBTU unit is based on your shop being well insulated with finished walls and ceiling, standard 8-9 foot ceiling height, minimal glass, any roll-up doors well insulated, etc. If any of these conditions are marginal, I would step up to a 24KBTU system. If these conditions are non-existent, and the shop is constructed as many garages are with no insulation, no finished ceiling (open to the rafters), etc. and you intend to leave it this way, you should perform a heat load calculation to determine the size of unit required. These conditions will dramatically affect the required heating and cooling equipment.
Ted
