@RJSakowski nailed it. I recently made this part for a knurler. Yes you could turn a taper and grind your shape in but concentricity would be a challenge. If making out of brass you could spin it in the lathe and shape it with a file. It would take awhile but could get you in the wheelhouse on dimensionsCan I turn a taper the same angle and radius of the ball? Then just face that down? So I don’t have to buy a ball turning tool? Then maybe shape the end if need be with a grinder?
