- Jul 2, 2014
- 7,594
The Servo power feed drives I have for my Millrite (Bridgeport take offs) coast to a stop after the motor switches off. They coast to a stop at different points depending on the speed in use at the time. I assume that the Asian imports copied from the Servo originals use a similar system. The cure is having your hand on the the handwheel ready to continue the cut at the speed you desire until just before it hits the hard stop (you do set the hard stops, correct?). I have not had trouble with using the stops. The soft stops kill the power before the hard stops limit the feed, and the stop parts must be set up to reflect that requirement.
I have seen many mill power feed installations that do not follow the installation instructions that Servo carefully spells out. The feed drive and the on/off switch only is not a proper setup.
