Life got in the way so I am back to this after a long recess
Installed a speed pot and a forward/reverse pot per manual. See pic
Set A001 =00 from 01 . Run from console turns on run light at 0 HZ. no motor run
Check voltage at "O" got up to +6V. NOTE I used a 5K pot, manual suggests 2K.
set A002=01 from 02
Both F and R switch bring in Run light but 0 Hz.
Set B37 to 00 from 04
Set B31 to 10 from 01
Now can read C01 is 00 => made no change
c02 is 01 => made no change
OK frustrated enough for now. what should i do next?
