- Dec 26, 2016
- 2,025
What is the best way to grind a shaft to receive an external retaining ring ? the ring's size is 7/32",thickness is .025" and the shaft is 1/4" O1 steel drill rod,this is the first time I'm preparing a rod for a snap ring,I have seen on youtube someone using a Dremel (with a grinding disc )doing the job fairly well but my lathe is not set up to hold a dremel.
I have a parting tool I could grind to cut a .025" groove, how does that sound?
