- Oct 29, 2012
- 1,329
What mill do you have?Most definitely. I remember searching all over and not finding much except for solutions that cost $$$$.
I really should have removed my table at the time but my HD sawhorses are mia.
Ok and after it has administered its shot, how long should pressure remaining the lines? Does it bleed away momentarily or does it bleed off slowly over the next 27 minutes?Basically when the oiler has power to it, it will administer 1 shot of oil in that time interval. You can't change the timer, but you can change the amount of the shot. It should be wired up so it is energized only when the servo motors are.
Make sure you have a friend, or better yet, a machine, to help you. The table is SO heavy. I mean it looks heavy, but it's even heavier than it looks. It weighs more than the knee.An oldie Series I VS 2HP Bridgeport 9x48.
Here's an original picture of mine.I can't make out the metering valve numbers though.
*edit* Found a better picture, shows FJB on the side of the fitting.
View attachment 313537[/S]
