Began an internal threading job on one of these lathes before I left today, 1 1/2-12 X 2 1/2" deep in the end of a rectangular steel part 3" X 3 7/8" X 8 1/2" long held in a 4 Jaw.
Don't ask why this is being done in a lathe rather then being drilled and tapped, they gave me a brand new GO-NO GO plug gauge for 4 parts. The gauge cost far more then a tap.
The canned thread program looks like this, all values may be changed.
ID = 2 (as a side note, in the tool library all tools are defined as OD Rough, ID Rough, OD groove, ID groove, Internal Thread and External Thread, if you choose a tool stored as External Thread for an ID threading job it will crash in spectacular fashion) keep this in mind. Also when programming a facing operation the roughing screen will give you 3 options,1 = OD, 2= ID and 3= Face, the Finish/Profile screen gives 2 options, 1 = tool on the left and 2 = tool on the right, if either choices are wrong it will often crash hard.
Lead = 12 TPI or .0833333, one may toggle between TPI and Lead, I always use lead, (this allows you to make a 3/8-16 1/4 thread so as to confuse someone in the future)
Thread Height is calculated by the control, I don't trust it so change it to a slightly smaller value like .o42"
Step= First pass DOC
Step 2 = All subsequent passes
Minimun Step = The last pass DOC
Spring Passes need no explanation
Withdrawal Clearance = The distance the tool moves away after each pass, this helps with chip clearance, keep in mind that when boring with a tool that fits closely in the hole to much clearance will cause the back of the tool to crash into the back side of the bore, this value is distance from the surface so .100" clearance is .200" on the diameter.
Engage Angle = The angle at which the tool advances much like manual threading from the compound
Start Z = Where the tool rapids to before threading begins, in this case .200" + .100" clearance or .300" from Z 0.000", (all moves toward the spindle from Z 0.000 are negative) a spindle encoder tells the Z servo when to start moving in relation to the spindle position, there is no gear train between the spindle and lead screw, you may put it out of gear between passes and it will not effect the position so long as you do not turn the power off or load another program, a blackout will screw you however, pun intended.
End Z = Where the thread ends, make this less then the blind bore, crashing a threading tool into a shoulder or the bottom of a bore is unproductive. Use an undercut at the end of the thread when possible.
Start Diameter = What it says, Minor Diameter of an internal thread or Major Diameter of an external thread.
End Diameter = The ability to make a tapered thread such as NPT, you are on your own when calculating these values. I have my methods of doing so.
In as much as the machine will do most of the work one must still set up the work set the tool, input the parameters and measure the thread just like doing it manually yet without all of the pesky 1/2 nut work, it is a thing of beauty.
