- Jun 20, 2022
- 215
Try spinning it with an electric starter. I have had some engines that no amount of hand flipping would ever start but started and ran fin using a starter.
Just pay attention to where the thrust load of the starter is going so you are not pushing the crank into the back plate. Normally the thrust load is taken up by the thrust washer against the front of the crankcase. Also when spinning with a starter if the carb is working you will see it draw fuel.
Do you have oil in your fuel mix? You only mentioned the ether and the kero. I have also only used actual pump diesel fuel, it has more BTUs for a given volume and makes more heat.
RE: Oil. Yes I purchased some pure cold pressed castor oil off Amazon. Hopefully that is the right stuff. From what I read castor oil is the go to. I also have some 2 stroke "Sea and Snow" oil I could substitute. I tried two different mixes with the same result: 25 castor, 35 JD ether, 35 kero, few drops of cetane boost and 25 castor, 35 JD ether, 45 kero, few drops cetane boost.
Ok so the above video I grabbed on the quick this afternoon. Thank you for the suggestion. What I am seeing is with an air bubble in the fuel line as a visual reference and the mixture needle wide open I do not get any fuel flow seen at all. Clearly there is a problem with either the internal airflow, or with the venturi in the carb.
I'm going to see if I can find a degree wheel I can print out and glue to some cardboard and map out the events. Apparently I gave away my old hotrod days degree wheel when I sold my Camaro. There is a lesson there about EVER doing away with tools because you never know.
