so i bought this cutter from Shars and some inserts from eBay and have had absolutely no success at all with it. I've tried all different feeds and speeds as well as DOC. The surface finish is disgusting and when cutting it sounds like I am beating my machine with a 2lb siege hammer. What is wrong? What am I missing? My Tormach superfly cutter handles speed, feed and DOC 10x better than this.
Do I have the wrong inserts? Is the Shars cutter a prime example of "you get what you pay for"? It seems solid and if the geometry is correct, shouldn't it work like a high dollar part? I was so excited to finally get a face mill to hog out some chips and all I got was a pit in my stomach from the thought of all the money I just potentially wasted.
cutter:
http://www.shars.com/products/index...g/2-45-degree-end-mill-r8-shank-seht-insert-1
inserts:
http://www.ebay.com/itm/10pcs-Korlo...rbide-inserts-CNC-lathe-Milling-/280778445770
cutter:
inserts:
