another thing worth mentioning I think, is don't be swayed by how the insert manufacture may label the geometry as "Roughing" or Medium Duty, I have a Bridgeport clone and ALWAYS use finishing inserts to Semi Finishing, they require less power, and sometimes have better shear charictaristics so it takes the load off the machine. for my badboy face mill I use a Mitsubishi ASX445 3" 6 tooth, the inserts resemble yours a little, and when I really want a mirror finish on steel I throw on an ACTUAL wiper insert, it doesn't look like the normal inserts its weird, it also hangs down about .008 below the other inserts so it makes its own finish cut after the other inserts make their cut. you can also run just 1 insert in your cutter body. or 2 if you have an even number. Fact is you don't have the power or rigidity to run certain insterts. neither do I, they are made for 20hp VMCs that don't have a lack of rigidity lol. you did do right by going with a 45deg cutter tho. the other guys are right, insert selection is tough, the Mitsubishi inserts I use are Cermets and cut most steels, cermets also don't like coolant or oils, I read that it can make them crack or whatever from shock, they work better with a little heat
