- Jun 12, 2014
- 4,816
Magnets are going to have chips sticking to it, I guess one could try some form of adhesive glue if you didn't want to drill holes. I used holders for zip ties that use a single mounting hole and I use an 8-32 screw that I tapped into the splash shield. They attach on the ledge, simple and works. Not sure about the long cables, mine are both the same length and form a soft loop in the pan, they are just long enough for the routing shown below and traversing the length. My lathe setup is a bit different, you may be able to route them on the back side of the splash shield and loop under and around.
