The Jacobs super chucks and the Albrecht keyless chucks are both very high quality chucks, and both are worthy of consideration. I think the thought for choosing between the one style and the other is how much heavy work you do, how many times you change the bit, and how big are the bits you use, on average, relative to chuck capacity.
Heavy work, leave the drill in the chuck for a lot of holes, use big drills (relative to the chuck size) a lot, choose the Jacobs super chucks.
Lots of drill changes, mostly lighter work, mostly smaller drills than the chuck capacity, choose the Albrecht.
Or, just get both, in all sizes and with tapers to fit all your machines... $$$$$$
I am lucky enough to have multiples of both, in various sizes. with multiple shank sizes, so I am also 'lucky' enough to spend way too much time choosing one for a given job. I have put together that collection over many years of biding my time and waiting for the right deals to come along. Patience, grasshopper.
With Albrecht chucks especially, I would stay away from one that has been really beat up and/or has marks from pipe wrenches and stuff from loosening the drill. Nice ones are nice, problematic ones can be problematic. Many issues with them are addressable by rebuilding the chuck, usually with the original parts, but you need to rebuild it properly. Mikey posted an extremely good 'how to' for rebuilding Albrecht chucks long ago on a different forum. It is the best one out there, better than Albrecht's instructions.
With Jacobs super chucks, again look for abuse and damage. They are damned stout, but not bomb proof. Only the Jacobs chucks that have the word "Hartford" stamped in them were made in the USA. Some others just say USA, but they are not... The "real" USA chucks are very nice, but the kits to rebuild them with are obsolete and getting hard to find and pricey, so watch out.
Buying used chucks off eBay or similar makes me cringe. I want to inspect a used chuck way better than that before buying it. Do you feel lucky?
The best thing is to mount the chuck and test it for runout on an accurate machine with multiple sized gage pins. I have never been able to do that until I got home after buying it. Dirty and/or dry chucks will not test at their best until they are cleaned up and properly lubed.
If I had to buy a new chuck today, it would be difficult to choose. Prices are quite high on the good ones, and quite low on Asian imports. I have a few imports that are decently good, and had others that have gone away. Do you feel lucky?
Edit: I also have two sizes of "Supreme" chucks, a 23T3 and a 14T33, made long ago in the USA that are very nice, high quality. The ones I have are in new condition. The 23T3 is about double the size of the 14T33, and is ball bearing, Both are 1/2" capacity.
