- Oct 18, 2016
- 2,872
I bought a Glacern for my Jet DP hoping to cure my runout questions. I ended up with runout that wasn't as good as the cheap Chinese keyless chuck.
Really? Mine is excellent. Did you contact Glacern about it?
FYI, what you quoted does not say Yukiwa chucks are made in Japan. Read it carefully.According to yukiwa-seiko all chucks are made in Japan : Yukiwa Drill Chucks are manufactured based on our standard which is higher than Japanese Industrial Standards (JIS) B4634
The quote that I posted from Glacern in post 17 above does not say that their tools are not made in China. Read it carefully. We all need to read things very carefully, lots of doublespeak out there.Hi Ken,
My personal preference is for Jacobs, Rohm and Galcern, in that order.
But be careful as some are B16 taper, and possibly Chinese copies.
The eBay listing you linked to is not a Jacobs chuck, it is a Jacobs taper. The chuck is a Llambrich CBB-13, you can see the name is inked out on the box. I think they are very good chucks, I prefere a 5/8" for larger drills depending on the drill.
It sounds like a good alternative but my heart is set on a chuck with ball bearing construction,although plain bearing chucks are not any cheaper . here's a link on why I insist on it:According to yukiwa-seiko all chucks are made in Japan
FYI: their website: https://www.yukiwa-usa.com/products/drillchucks/index.php. This is the website for Yukiwa Seiko usa, inc and in the upper left hand corner it says: all drill chucks are made in Japan. Not sure how to check if web site is lying?FYI, what you quoted does not say Yukiwa chucks are made in Japan. Read it carefully.
MSC sells an accupro made in Spain for $84.84 if you can get the old Enco discount. JT6 , 1/16 to 1/2" ball bearing chuck.New. I've only used the accupro precision shanks- and they are excellent quality.I see, nice catch,, still it is a good price, slightly cheaper than Amazon, that Vertex is not too bad and it is available on Amazon Canada at a good price although it is temporarily out of stock.
https://www.newmantools.com/jacobs.htm
