[4]
Kondia owners? Clausing Kondia standard head manual machine owners?
[3]
[10] Like what you see?
Ropata
Active Member
May 24, 2016
141
Just arrived in my garage is this lightly used Kondia FV1. Any owners on here with some helpful info on parts and spares would be greatly appreciated. My main concern at the moment is the auto quill feature. As you can see from the video , I'm not sure if I can't work it out or It's broken. I'm also keen to hear if the old oil recommendations have modern equivalents
Shootymacshootface
Active Member
Mar 17, 2018
322
There is a lot to cover here.
I'll start on the right and work to the left.
The small lever on the right side activates the whole down feed system. The threaded rod on the very front is also part of the down feed system. There are small levers at the top and bottom of this rod. These parts must all move freely. The quill must be slightly lowered to engage the feed. The lever on the front that moves left to right engages the feed. Move it to the right to engage. The depth of cut is set with the quill stop on the threaded rod on the front. This will make the feed lever kick out automatically. The small lever on the left side controls the feed rate.
I use bar and chain oil on everything that requires oil and on the back of the head there should be a plug or a grease fitting, probably marked with a "B", that hole takes grease.
I hope that I didn't miss anything.
Good luck mate!
John
Shootymacshootface
Active Member
Mar 17, 2018
322
I did miss one thing. The rod that is missing a knob on the end is a push pull controll for the direction of feed (up, down, and neutral).
Ropata
Active Member
May 24, 2016
141
Thanks for the great advise. I've been playing around all day and it seems the engagement handle won't stay in. I'll post a video shortly.
Shootymacshootface
Active Member
Mar 17, 2018
322
The threaded rod/quill stop/2 levers/button to the top right of the threaded rod is most likely stuck in the kick out position. Pull or pry up on the threaded rod, it should move about 1/4".
Ropata
Active Member
May 24, 2016
141
I think i see what you mean, I'll play around some more.
Shootymacshootface
Active Member
Mar 17, 2018
322
Lower the quill about 1" and lock it. Now you can troubleshoot the kickout linkage. The button on the upper right should push down much further than you did in the vid. Once you get everything freed up the feed lever should lock. Try pushing down on that button and prying up on the threaded rod at the same time. Don't forget to lock the quill about an inch from the top first.
Ropata
Active Member
May 24, 2016
141
The quill was locked about an inch down during this video
Shootymacshootface
Active Member
Mar 17, 2018
322
Yes, they are very close, and many parts on a Kondia will interchange with a Bridgeport. That is part of a detent for that button that the quill pushes up on.
This is what these parts should look like for the feed lever to engage. Mine is sticky too.
Ropata
Active Member
May 24, 2016
141
yes the plunger under the scale that knocks the engagement back was just really sticky. Seems to be working OK now.
[6]
[5] [7]
