- Apr 23, 2011
- 2,476
.....I will be returning the entire machine very soon! ...
I have just sent you a PM with the warranty return address on it. I'll let you know when it is ready for you to pick up again
cheers Phil
By the way, this came unattached to the machine with no screw...I will be returning the entire machine very soon! :lmao:
Stay tuned for more folks!
Looking good...
I'll find-out about the MT4 vs MT3 issue. Maybe there is a different ram that can be obtained... Don't know but I'll find-out. As for the motor, when you push the lever down, it should spin in the normal cutting direction. If it's not doing that, then the terminal block wiring in the motor is probably reversed. First, let me know what direction it spins when the lever is pushed down.
Ray
The MT4 vs MT3 Is really no issue at all, just means I need to invest in a whole $25 worth of adapters, no big deal!
When I push the lever down it spins in reverse, or clockwise. I have to pull the lever up to get it to spin counter-clockwise and cut.
