Just curious... In the opinion of the group, if you have a really nice milling machine (ie. Bridgport) is there much need for a face plate on your lathe? Seems to me the mill would have you covered 90% of the time...
Since about 2007, I have had a Bridgeport clone that qualifies as a really nice milling machine, and two lathes, a 10” Logan for 10 years and a 14” Takisawa for 5. I didn’t have a faceplate for the Logan, didn’t miss it at all, and while I have a 12.5” faceplate for the Takisawa I have never used it. I don’t see much use at all…though I have a 12” rotary table that is used infrequently and might substitute for some faceplate ops.In the opinion of the group, if you have a really nice milling machine (ie. Bridgport) is there much need for a face plate on your lathe?
That is a bit like asking if ”you need more tools?” The answer from this group is going to be “YES”. Granted, I don’t use the face plate very often, but sometimes it is a better solution to getting a certain job done.Just curious... In the opinion of the group, if you have a really nice milling machine (ie. Bridgport) is there much need for a face plate on your lathe? Seems to me the mill would have you covered 90% of the time...
eBay, FB, this forum. Parts for that lathe are out there. I have a 1942 13" and was able to scrounge up some NOS parts for it. As far as a faceplate for it, you juts need to find one with the right thread for the spindle. Or make a back plate for it.When I got the lathe, 16" SB, the face plate and anything associated with it was missing. I would like to get all the parts together so I'd have the option. But dang, where in the world do you scrounge up parts for a 1962 SBL? Plus, looking at the parts diagram it looks like there is a bushing that goes in the spindle that holds the Morse #3, a thread protector (?) then the face plate...Am I correct?
I am a rookie when it comes to face plates...
