- Dec 20, 2021
- 906
Hi,
Considering doing a rebuild, or upgrading to a different lathe.
Currently there's a Sheldon EL-46-P in the basement. It's pretty worn out, mostly from wear and abuse from many decades in a high school shop. But, I really like this little lathe. Nothing is broken, just worn out. Lead screw seems OK, but the tail stock seems particularly worn out. The thought would be to send it out to a shop to have all the ways machined/ground/scraped. Basically rebuilt, at least mechanically. (I doubt having someone else paint it is within budget, and maybe the old patina would be a better look anyway!) The plus with this machine is I have a fair bit of tooling. Bison 5C Chuck, 4 Jaw, 3 Jaw, Phase II quick change tool holder, and import DRO. Other than lack of taper turning, it's set up with most of what I need. Probably the biggest limitation is the tail stock drilling depth.
...Or, start shopping more seriously for a Hardinge HVL-H. Even a little worn 'super precision' lathe would be better than what's here currently. I think the HVL-H fits the bill more closely for what I tend to do. Although they tend to run on the more expensive side. What sorts of issues would a guy look for on a Hardinge? Pros/Cons, etc?
...Or look for a __________ (fill in the blank, suggestions here). Most of my lathe work is small parts. In a variety of materials (copper, brass, aluminum, hard steels, tool steels). Currently getting set up for ID/OD grinding, and some other ideas which are much crazier. For the most part I care about accurate precise work over hogging off material. I'd prefer a smaller machine, maybe up to a 4' bed. Power available is 120/240v single phase (Sitting close to 200A panel). Although, I could come up with a VFD or rotary phase converter if needed. (Current lathe runs on a Phase-A-Matic).
A rebuild is in the budget based on a quick phone call. A 'good' HVL-H might be a little on the high side, but not completely out of reach. A new Kent USA copy of the hardinge is NOT going to happen!
So, thoughts, suggestions, comments, questions? I'm all ears at this point.
Dan
Dan
