- Jun 29, 2014
- 4,062
I parted out my old Atlas 10F and got another one. The second one had a bunch of accessories and the QCGB. For once, I'm on the plus side of the ledger with my hobby in more ways than one.
It also came with a bench. Two layers of 3/4" plywood with a stainless skin on top on 4x4 legs and heavy framing. Good bench whoever built it. First project I made with the lathe was some small brass knobs for some "Dandy Drawer" style drawers I made out of maple. The tapers on the knobs were off on the first couple, so I thought maybe there was some twist to the lathe.
1) I used 5/16" studs about 4" long,
2) Tightened the studs to the bench, sandwiching the benchtop between two washers and two nuts,
3) Sandwiched the mounting feet between two more washers and nuts,
Now the lathe is about 3/4" off the bench.
4) I leveled across the ways first, nearest the headstock. I used a six inch Stanley precision bubble plane and got it close.
5) I leveled across the ways second, nearest the tailstock. Same level same procedure.
6) Leveled longitudinally, 8" Starrett precision level. (Mostly, the tailstock had to come up)
OK, now I'm ready for the "two collar" test. Although I didn't rough out collars.
7) Chucked up a 1" bar in the 4 jaw and indicated it in to about +/- .001". I didn't cut the collars, just took a 6" long cut in mild steel.
First cut, I was about .010" large on the diameter, nearest the tailstock. Definitely some sort of twist, or so it seemed.
8) I gently adjusted the makeshift, operator-side, tailstock-end leveling foot, gently tightened. Checked all my bubbles again, could see a slight shift in the one near the tailstock, but still between the lines.
Second cut revealed a difference of .001" diameter between the collars. I figured I'd quit while I'm ahead.
Question, is there more to squeeze out of this or do I call it?
