- Apr 24, 2021
- 462
I have a one piece vertical engine block with cast iron sleeves. I have a pm1236 lathe. I need to bore the sleeves out at least .020in. I was hoping I could make a jig for the carriage and power feed it towards the chuck. It’s a v twin, so I would have to make sure to set it up at the right angle. The other problem, it’s not technically line boring, since the tool I would make will only be held in the chuck and maybe a steady rest for added rigidity.
Is this possible to do? You may ask, why don’t you just send it to a machine shop? The answer is, I can’t afford all 65 of my hobbies. Also, I want to see what I can get away with on a cheap high hp build. Please let me know what y’all think.
