- Apr 24, 2021
- 462
That easily could be done on our L&S or our old 1917 south bend.
The older machines had t slots on the carriage just for this TYPE of work.
Can yours, maybe.
Line boring required a bed long enough to move the work PAST the cube that is mounted in a mandrel between head and tailstock.
The alignment needs to be perfect.
Work held on carriage perfect.
This is a quick and cheap job for a engine shop, they do These in their sleep.
You will not save any money, your setup time will be long and one chance to destroy your block.
Also of note, how thick is the special lining?
We changed rings in a Command 20 that had so many hours the rings were almost gone, but no Ridge or bvious wear in the cylinders, look at getting correct size pistons Orr correct shop.
Sent from my SM-G781V using Tapatalk
Thats why I was saying lay it on its side and make a boring bar similar to line boring tool, but it wouldn’t be between centers. It’s looking like my lathe is too small for that even.From my experiences with kohler v-twin engines I would have to say I don’t think your lathe would have the swing to bore a cylinder. Have you checked?? Also you would need to bore about three to four inches length. Which I would suspect would be pretty flimsy. Idk the standard way would be setting up in a mill or dedicated boring machine. I think your best bet would be a mill and a stout boring head.
