those are nice lathes.
I was tempted to get a Five a while ago, but because I couldn't find parts supplies etc I ended up passing. My best bet would be to look at 3rd party companies like Boston Gears that can get you the gears you need, but you would have to know the size and tooth count of the gears in question - do you have documentation and/or existing (broken/worn off?) gears to get those numbers from?
Colin, how many and which wheels do you need? I recently cut five for my LittleJohn. And made a new rack pinion. And took the cross slide intermediate wheel to the dentist to replace three missing teeth. And made a cross slide pinion
I'm getting good at LittleJohn wheel cutting
Richard
Hi Richard,
I'm looking firstly for a 44 tooth gear for the metric conversion, I already have the 52 tooth gear, afterwards it may be time to invest in other gears. the lathe only came with what was in the basic end gearbox. Your help and interest is much appreciated. I do not like Dentists.
Thanks Colin.
is yours a later little john? I'm asking because i have a paper copy of the thread cutting table, so i made up the missing wheels and found they wouldn't fit. I had to drop spindle b down and cut away the casing to make it work. I have recently bought a second little john (i'm planning to breed them) which has a different chart.
this lathe uses a 63 and a 68 tooth wheel to cut metric, neither of which i have. I suspect that they were an option
if the distance between shafts a and b is around 2 5/8" this is the correct chart. If it is around 2 13/16" the chart you have is correct
richard
richard
