excellent. So you have two 30 tooth wheels, two 60 tooth wheels and a pair of 45 wheels for the a and b shafts? I had to make most of those
have you checked that you can remove the wheels on the back of the b and c shafts? I guess that you will be able to. I couldn't on mine so i remachined the shafts
it does sound like you only need a 44 tooth wheel
richard
hi richard
i must have not made myself clear, the lathe came with only the gears fitted in the gearbox no change gears at all, i managed to obtain the 52 off the internet, i have had to have two gears made because when it was in service at my works some moron allowed a cleaning rag to get into the saddle gears!! This caused the feed-screw shaft to lock and shatter two of the lathes gears, one which drives the d spindle gear, the other was the gear which is connected via the screw cutting shaft, so before i do anything else to the beast i will wait until these gears come back to me from a chap in the midlands, next week i hope.
P.s. Just fitted a quick change tool-post, much better!!.
Colin.
