- Dec 24, 2020
- 1,055
The machine looks complete and should be worthy of a cleanup, once you get it running you'll be able to tell what condition things are in.
I'm not saying he shouldn't buy it, but if you zoom in on the pics it doesn't actually appear to be complete. The lever for selecting power feed to the saddle/compound is missing, as is the clutch knob/lever assembly. Also, the threading lever is in an odd position so all of that says there's some sort of issue in the apron that could be a major issue. Similarly, the QCGB has been removed at some point and replaced with only two of the four bolts, and the wrong kind of bolts were used....could be another major issue there. Logan parts aren't terribly rare, and maybe the missing parts are somewhere in the pile, but it still could be a challenge for someone if they aren't up to repairing a lathe (which often takes a lathe).
