- Apr 14, 2014
- 3,189
Over the years I've found trying to buy bolt "assortments" is a losing proposition. I gave up on the idea back in the 1970's and started buying them in bulk from either the local farm store or McMaster. I keep hex head sizes from #4 to 1" in stock. I usually have multiple lengths by 1/4" and hardness of #2, #5, and #8 from 1/4" to 1/2" diameter.
I also have the more common lengths of socket head bolts from 1/4" to 3/4" in diameter. Button head and other specialty fasteners are usually bought as needed by the box from McMaster. I store the specialty fasteners and socket head bolts in Plano storage boxes similar to this:
As an FYI there have been times when I've had to cut bolts to length. However, I avoid it whenever possible. In many cases the unprotected ends of the bolts start to rust diminishing the appearance of the project.
The hex head bolts are stored in the drawered cabinet on this bench.
