I took the plunge and bought a Harbor Freight 20 gallon parts washer.
They are rated for water based solution so I spent a lot of time deciding what I wanted to try.
I settled on trying the Krud Kutter parts washer sold at tractor supply. The minimum mixture recommended is 10:1. I decided to start with two gallons KK to 10 gallons of water.
With soaking that should be pretty good but I also filled a quality spray bottle with 50/50 Krud Kutter and water. That will help develop some pressure to get into nooks and crannies...
What are you guys running in your water based parts washers?
