- May 13, 2019
- 1,016
Can anyone recommend a miniature drill chuck for a range of No 60 bits to about 1/4"? Something that can be chucked in larger chuck or collet and not too $$$ would be ideal.
My we ask what your application is/will be? Holding a chuck in another, larger, chuck can (will) result in broken bits at the small end of the range. You would be better off with an arbor directly mounted in the drill press/mill/lathe tailstock to achieve the smallest runout, or better yet a chuck with a "sensitive" adapter to give you better feel.Can anyone recommend a miniature drill chuck for a range of No 60 bits to about 1/4"? Something that can be chucked in larger chuck or collet and not too $$$ would be ideal.
The drill chuck will be used to drill small holes for a clock project I'm working on.My we ask what your application is/will be? Holding a chuck in another, larger, chuck can (will) result in broken bits at the small end of the range. You would be better off with an arbor directly mounted in the drill press/mill/lathe tailstock to achieve the smallest runout, or better yet a chuck with a "sensitive" adapter to give you better feel.
Charlie
