Ok, I'm still digesting this. I've started to ask a question several times, but then thinking it through I find the answer is actually somewhere in what you have written, either specifically or readily implied.
I keep thinking if a sharper angle is less work for the machine, then why not more. Obviously there must be a point where to much is too much, and I keep coming back to an answer only to read through you posts again and see this.
Guys, there is something about a 15° relief angle that just works. I don’t know why this is; it just works.
Considering how often I seem to see this angle in your tools, that explains a lot.
At least on our end it seems like the very simplified summary is shallower angles are easier on the tool (less need to sharpen) while the steeper angles are easier on the machine (cuts better, with less force).
One item that seems to have only been briefly touched on is tool size, larger being more rigid, smaller being cheaper and easier to grind. I'm not seeing anything to suggest the tool size has much effect beyond that. What works well on 1/4" will probably work even better on 3/8" or 1/2".
The trade off seem to be cost, and grinding effort, vs stiffness and tool durability. Does that pretty much sum up tool size?
Perhaps some minor fine tuning needed based on the tool flex, but a bigger tool doesn't seem to result in a larger, less agile contact point, it just has more material backing it up.
I've been using 1/4" tooling all this time and when I was playing with aluminium and brass that seemed fine. Steel seems to be more of an issue, so I've bought some 3/8" blanks to try out to see if the additional rigidity helps on these harder materials. Nothing too fancy just 12L14, and some hot and cold rolled.
I'm going to carve one of the 3/8" blanks into a square tool and see how that goes.
