It would not be good if you were off by a factor of 10, cST 9.5 at 40C is ISO10, but at 100C is ISO100. I would take a little out, if it pours like water then it is ISO10, if slightly viscous then it is more likely ISO100. Typically low speed gearboxes for drives would take an ISO100 or 75-90W gear oil, I have only seen an ISO10 "spindle oil" used for high speed applications "high speed bearings, machine tool spindles and some high performance hydraulics". If this is for drive gears, ISO10 would peobably be too thin to coat the gears.
