- Jul 20, 2014
- 1,386
Thank you all.
The part in question is a Dotco die grinder end plate.
The design seems sound but could use a little improvement. i.e. Roll pin hole would be better
with a small slot on the other side and two slots for pushing out the miniature bearings w/o destroying
it to get it out.
Carbide burrs: I have a few of them from dental supply houses as well as Guhring solid carbide drill bits, 1/16"
and dremels/bits. If i were to use a dremel burr, which one exactly should I try? Most are 1/8", too large.
I want to attempt this on a milling machine.
Thanks
it to get it out.
Thanks
