You mean the radius fought you? I know that my lathe can't turn steel with that radius form tool. Did you lathe handle that or is this the part you meant that you used a larger lathe for?This is the only tasks that fought me and I ended up using the larger lathe to make it... too much chatter with this lathe. Keep in mind that I am new to all this... so user is most likely at fault here...
