- Mar 10, 2013
- 1,428
hope this is in the right forum. I am working on my Case 1537 skid loader that has a Wisc. v4 motor--the starter sounded very bad and so I removed it. the brushes were about gone and the armature very rough. the man I bought the loader from gave me another starter with it. I put new bushing on starter end and then I realized it was a 10 tooth drive gear and the one I took off was a 9 tooth. how do I know what is the correct one--9 or 10 tooth? Case dealer said he had no info.
does any member on here know for sure ? It is not easy to just put the starter in because of it's location. hopefully someone is an expert and knows the different applications for 9 tooth and 10 tooth starters. they are both starters without the solenoid on the starter.
thanks Dave
thanks Dave
