- Dec 27, 2012
- 39
The G0704 seems to be a popular machine to CNC. My reason for asking is I currently do not own a mill. I want to buy a mill either dedicated CNC out of the box or do a conversion to CNC. Although it will initially be for hobby, I also have in the back of my mind using it to start a business when I retire. If you could comment on the following I and probably others would benefit from your comments:
1. What you estimate it would have cost to CNC the 0796
2. What you estimate it would cost to CNC the 0704 (even though you still own a few parts)?
3. Why you'll go with Mach 3 even though Mach 4 is available?
4. Why do a conversion vs just buying a true CNC machine out of the box.
John.
Hi John:
I would be happy to comment on these excellent questions. Now gentlemen, these are merely opinions, no doubt they conflict with someone else's opinions which makes neither opinion correct. Please feel free to give your own opinions in addition to mine.
1. The cost of the retrofit to CNC for the G0796 I calculate at approximately $6,150. Add to that a computer, real 25 conductor parallel cable, keyboard, mouse and monitor (touch screen preferably) if you do not already have those items. This broken down is $1500 for the Automation Technology CNC kit, $1500 for the X axis ballscrew (and this is losing 1 inch because the ballscrews out there are for 48 inch tables, $1200 for y axis ballscrew, $1900 for the knee (many will not want to CNC their knee), $200 for a yoke. This assumes you can machine all the brackets to install the motors yourself. If you only have one mill, you may have to buy those or take a huge amount of time and several tries taking the machine apart and putting it back together over and over until they are right. Removing the table, saddle and the knee on a Bridgeport clone is not a trivial matter.
2. The cost of the retrofit to CNC for the G0704 I calculate at approximately as high as $2200 and as low as $550 depending on what you want the mill to be able to do. Also add the computer and peripherals as above if you do not already have them. This broken down is as follows: The Automation Technologies kit at the high end $1500 and the low end $500 depending on how much power and speed and control and precision you want at the ball screw. $700 for the G0704 ballscrew kit for all three axes with brackets from Automation Technologies or no additional cost using the original lead screws (An additional $100 would add anti backlash nuts for the ACME screws which actually work great.
3. Mach3 is more for individual users and I am familiar with it, it is easy to install, easy to run and does what I need it to do. It is also cheaper. I am a cheapskate. Mach4 (what little I know of it) is more for OEM's and propeller heads, I want to make parts not fiddle with a new interface. I can always upgrade later.
4. Converted CNC's are true CNC's. I cannot buy a dedicated CNC machine of the caliber and ability I want for $3500 which is about what I will have into the G0704 when I am done. I also will have to compromise something in a way I do not want to compromise if I buy a CNC machine already built by someone else. But by far the most important reason for doing it myself is that I will know everything about servicing the machine. If I buy a machine put together by someone else I will have no idea how to repair it when it breaks,,,,and it WILL break. Service calls are horribly expensive and you never know how much it will be until they show up.
Hope that helps John
Barry
