I jumpered the bottom right terminal to L1, and still the same result as above. At this time, terminals 1, 5, and 6 on the drum switch have L1 connected. In the off position, I still get a hum from the motor when I plug it in. It doesn't rotate in either direction, just hums. When placed in either the forward or reverse positions, *then* plugged in, the motor rotates the correct direction, but will not stop when the switch is moved to the off position.
I've been looking around on line, and was curious. This switch originally controlled a 3 phase 220v motor, and now I'm asking it to switch a single phase 115v motor. I've seen a number of different drum switch internal connection configurations out there. Is it possible that this is just the wrong switch for this task? Just wondering. Thanks!
GG
