It has been slow going, been running the 3d printer to make a little cash to continue with the cnc project. One thing I can tell you all, if you want to convert to a 3-phase motor, but keep the weight down, I suggest going with a metric motor instead of a nema motor. Leeson has a nice one that has a D80C frame, which has the same bolt pattern as the 1.1kw sangmutan motor. A nema motor will add 40 plus pounds to the head, but this motor is only 34 pounds. Well within the capabilities of the nema 34 970oz stepper, or even the 570 oz nema 23 stepper. It has 1.1kw (1.5hp) of power and is physically smaller than the nema, looks nicer too
. I modified the motor plate for my belt drive kit (it had threaded holes, I just drilled them out for M6 bolts and counterbored it for the socket head screws, and that was all there was to the mechanical mounting. The only other difference is you will need to bore your motor pulley to 19mm and put a keyway in it. the originals are 14mm and they will not fit as is.
