Update: Been working a lot of hours, not as much time as i would like to work on the machine, but i do have some new information, and should have some new pictures to post later this coming week.
1st. Been looking at motor options, vs the stock motor. The PM25MV i am probably going to leave alone for now, and change the motor on the cnc machine head. What I have been looking at: At first, i thought i would go with the Sangmutan motor that Keling/Automation Technologies sells. Then i saw the multiple threads of problems with the controllers of those motors. The threads say they have been updated but there still seems to be a few nagging problems with them here and there. Then I looked at a three phase motor, this has more promise, but the 56C of a nema motor is quite large for the mill head. I started looking at 3 phase metric motors, it appears that the Sangmutan motor has the bolt pattern of an IEC D80C metric motor. this is good news. A D80C motor is a bit smaller than a 56C for the same horsepower. I ordered a 1.1kw (1.5hp) Leeson motor, model number 192067.30, this motor spins at 3600 rpm, and with a vfd should give a very nice rpm range for the mill. at the face mount flange, the Leeson motor is only 1 inch diameter bigger on the outer edge of the flange than the Sangmutan motor. The motor mount plate i already have is made for the sangmutan.
2nd. The bad news. The D80C motor has a shaft of 19mm diameter with a 5mm key. The sangmutan motor has a 14mm shaft with a 4mm key. I am going to have to bore out the motor pulley and broach a larger keyway. Also, the increased motor diameter may overhang the motor mount bolt slots, so i may have to countersink them for flathead screws to clear the motor flange, i hope not, but we will see.
3rd. Picking a vfd. I am familiar with vfd's, i had one on a bridgeport i used to have (it was a teco unit). I am thinking about getting a Leeson nema 4x enclosed drive and mounting it directly to the mill head, where the electrical box originally was. the problem is the nema 4x units are quite a bit more expensive than the open frame ones. The trade off is that the open one should be in a pretty large enclosure, which i do not want to mount on the mill head (10 x 12 x 8 box). Another option is the Hitachi WSJ200 drive. While this is not nema 4x, there are wiring diagrams available so i can hook it up to my C32 breakout board with no problems. Not so with the nema 4x drives. Tough choices, and all somewhat expensive. I am still undecided at this point.
