I have several 5 ton and a couple of smaller condensing units that I would like to see go to better homes. Lacking the air handler (inside unit) selection of electric, gas, or none for the heat can make installation fairly straightforward. Sure makes a difference. Last year I put word out with a couple of A/C buddies and came up with more than I need. I'm running a 3 phase 5 ton air with a 15 KW electric air handler. My shop is only 30 x 40, and it can freeze you out, or cook you....as wanted.
Granted, it's a lot more involved than simply installing a window unit, but in the long run, seems to be the better way to go to me. John, if it's not too late and you want to consider this route, let me know.
