- Mar 5, 2012
- 314
I am working on my Hummer (H1) the tire inflation system.
there is a spindle extension (a hollow pin) it is about 5/8"dia. and 1"long half ( 1/2" exposed)
'with a 7/16" thru hole, is pressed into the out put shaft in the geared hub that a seal rides on.
The pin is very hard and smooth (chrome plated) I have not been able to tap it (tap breaks due to hardness of the pin).
I am thinking of some how make a puller that I can tighten onto the outside of the pin then have the out side of the puller threaded so I can tighten a nut that will push the pin out.
I think the inside of the tool needs to be tapered so it will grip onto the pin, then the outside taped with straight threads,
How can I put a taper on the tool with threads for tightening it onto the part?
