Is the lathe everything you expected? I am looking for a new lathe, if I keep with the 8k budget I have been looking at this lathe or the grizzly G0509G.
I have several hundred hours on the lathe now and it has met or exceeded my expectations. I have done some modifications which are documented in
this thread.
The lathe is very well made, very accurate and easy to align. The bed castings are very nice and of high quality. Everything was smooth from the get-go. The 2" spindle bore, D1-5 spindle nose and short head stock are a big plus in this size of lathe. For a gear head lathe it is very quiet to operate.
The steel stand is heavy duty and provides a very solid base. The back splash and belt cover are 1/16" steel and very solid. I did not get the premium package and chose to purchase my own chucks. I wanted an adjustable 3-jaw and a 4-jaw with 2-piece jaws.
It does require change gears for metric threads and some of the less common imperial threads. Most of the common even numbered imperial threads can be cut with the same gear set. Gear changes are quick to do so it has not been an issue.
The downsides were some of the specifications were not what was claimed. The spindle height was lower than advertises at 43" vs 47". The cross slide travel is only 6.4" and not the 7-1/2" in the specs. This one irritates me the most as a 14" swing lathe should have at least 7" of cross travel.
The t-slot in the compound was not cut true. I discovered this when I machined a T-nut for an Aloris QCTP. This required some shimming to get it to sit correctly in the T-slot. The back splash and belt cover were poorly fitted requiring some rework. This does not affect the performance of the lathe just an annoyance for a $7k lathe. I have spoken with other PM-1440GT owners who did not have this issue so I may just be the lucky one. I was suprised it was not caught by Precision Matthews when the un-crated and inspected. It was quite obvious.
The access for the coolant pump and tank is from the inside face of the stand which would be impossible to get to if the lathe was backed up to a wall. It should have been on the outside. Mine backes upto the overhead door so it is not a problem for me.
My lathe came with the single phase 2HP motor. I have since changed to a 3HP 3 phase Marathon motor. Having run both motors I can say the 2HP single phase is undersized for this lathe. The factory 3hp 3ph motor would be a better choice.
The G0509G was on my short list. I think it is a lot of lathe for the money. 1500 lbs heavier, one-piece cast iron base, 10" ways, D1-6 spindle, 2" spindle bore, no change gears etc. My reasons for not going with the Griz were size and power requirements. I was very tight for space and I would have had to done a service panel upgrade to provide the power to it which would have added many thousands to the cost. Also I had a lot of BXA size tool holders and tooling from my old lathe that would be too small for that machine. I don't need a 16" swing lathe for what I do and I can tell you that an 8" chuck is about all I want to deal with without a hoist to move it around.
I have no regrets in purchasing this lathe as it meets my needs perfectly.
