- Aug 15, 2013
- 2,118
Mike,10" is not a lot of room on a milling machine. With the vise and tooling in there, things are going to be tight! My Sherline mill has about 14" of space under the spindle and I can just get my little 4" rotary table and a Blake Co-axial indicator in there; these tools wouldn't fit on a PM 25.
I see your point about room for RTs, tools and such, but I might respectfully point out that David’s mill has 12” max from spindle to table. The head only moves 10”. But even with 12” clearance, I can see how an RT with a chuck on top and a work piece mounted might limit tool space.
FWIW, the spindle to table clearance (to nearest 0.1”) on my LMS 5500 (Sieg SX2.7) is 12.3” max and 0.6” min with the quill drawn up in the “home” position, not extended. I actually didn’t know it would get that low to the table until I tried it just now. I’m not sure how practical that is, but I know now that if I ever need to use it as a panini press, it’s up to the task.
Meanwhile, back at the ranch, the head travel measures 11.7” top to bottom (vs 11.6” advertised). Quill travel is 2.8” (as advertised).
Tom
