- Dec 27, 2014
- 4,058
Has anyone built a vertical mill for wood with a worn out small drill press and a Dremel tool? Negate the motor and spindle, mount the tool in or on the quill, mount a 1/8 to 3/16 milling cutter in the tool and be able to fix that a defined distance above the table so repetitive cuts could be made (in wood) ?
For instance, inletting a cut for hinges... or inlay work.
