Moderatemixed,
First off, that is a beautiful machine. You'll have a lifetime of fun/satisfaction with it.
Regarding the stand offs, I know there are machinists who will disagree but I three pointed my Atlas lathe with 2.5” risers on the headstock end and a single center point on the tailstock. Since I move my lathe around in a small shop on a bench with wheels this allows the lathe to have a “natural” levelness. I can take .025” cuts in steel with no issues. In aluminum .050” easily. I suppose if I took much deeper cuts there could be a problem with bed flex, but I haven't noticed any. I do use razor sharp 3/8” or 1/2” HSS bits. An AXA tool holder is perfect for that 10” lathe. Also, a singe piece plinth on the cross slide (replacing the compound) will make for a much more rigid setup. I made mine out of round stock aluminum. Same height as the compound.
Mike
