- Nov 25, 2015
- 335
The plinth is basically a big block of steel, same height as your compound but bolted to the cross slide. Stefan G, Rob Renzetti both have YT videos on how they made theirs.
Here is mine on a 10x22. Not quite wide enough, will be widening the base soon. In your case a tall piece of round steel the diameter of the base will be all you can do.
No doubt somone will pipe up and say 'but then you can't thread' which might be true from the usual North American approach but in EU it is normal to plunge straight in for fine threads (which is pretty much anything less than 13tpi) so not really an issue.
I still think you should just bolt the lathe to a 7 or in wide u channel
Thanks G. I really appreciate the further insight. I think I might look at what Pierre has done with his vs the metal u channel for the time being. I have an idea and will discuss tomorrow. Thanks as always for the insight....
Cheers, Big B.
Derek
