- Feb 25, 2021
- 3,146
Same thing, even though my CK has a VFD! I have a 4 position switch on the VFD enclosure on the back of the lathe. One position is for the RPM to be adjusted by a pot on the lathe front panel. The other three positions are 40, 60, and 80Hz. It stays on the 60Hz position, and I shift gears. With dual clutch and brake levers, mechanical is easy.Another thing is I my lathe is a big, hefty old gal with 16 speeds so I haven't felt a need for variable speed. And I actually enjoy handling her knobs to change gears.
I also find that it makes me think a bit more about feeds and speeds, rather than just twisting a dial randomly.
