- Feb 1, 2015
- 9,622
Hi Franko,
I have had poor experience with shallow pitch canopies. They always seem to puddle water, no matter how tight I stretched them.
Something that I did years ago was to make a Quonset style canopy. I was doing some boat work myself, sanding, scraping, priming, painting, and wanted to keep the boat dry. The advantage of the Quonset is the low peak and shallow pitch in the middle but the steep pitch for drainage at the edges.
I used some 9/16" steel rod salvaged from silo tie rod but 3/4" conduit or similar should work as well. I bent the rod into the proper curvature and sunk the bows into the ground to create the frame. I don't recall how I tied them together; I may have just lashed cross bars in place. The canopy material was one of the ubiquitous r-enforced poly tarps which was stretched over the frame and staked to the ground.
You would have multiple options depending on whether you wanted a take-down or "permanent" structure. some tee and/or cross connectors could be used to make assembly easier. Bow materials could be solid rod, thin wall conduit, or sch. 40 pipe. A larger diameter PVC pipe could also be used, the advantage being tees and crosses for connectors are readily available.
If you decide to go with the roughing end mill for notching, I would suggest cutting a vee notch with the band saw first. Much less material to mill out.
Bob
Bob
