- Jan 2, 2019
- 6,555
Come on! Hammering it on is so Mickey Mouse! And so is gluing it on.
Work out a way to secure it mechanically.
Modern adhesives are actually very good at this type of thing. The main bearings in my racing engines would typically be an interference fit with heating an aluminum case to receive the bearing. When these bearing races became oversize it caused all kinds of problems for what was essentially a lawnmower engine modified to run at 8500 rpm. The loctite bearing retaining compound solved the issue and allowed me to rebuild many engines that would have otherwise required a replacement case.
If you do some research you'll find out that many modern cars and other products have adhesive in places that used to be welded. The adhesive process is faster, cheaper, and more reliable, otherwise manufacturers wouldn't be doing it. The science has come a long way in the past few decades and it's used in many mission critical applications where only welding or mechanical fasteners were used in the past.
Cheers,
John
