- Sep 8, 2019
- 4,392
So I made a male 1/4-20 thread as seen below. The fit seems to be perfect because it started out tight and the Grade 8 nut served as a die.
I am having an issue with the lathe turning a taper. I have suspected this since the first day I got it. It has nothing to do with the tailstock. I might need to adjust the position of the spindle.
If I chuck up even the most rigid round stock and turn it as carefully as possible, I will get a taper of about .0007" per inch.
For this bolt, I attempted to turn a major diameter of .2500", I turned .2500" at the far end, and the workpiece was .2514" at the chuck end. Same story for the .2175" pitch diameter. This was the first time that I used my Shars screw pitch micrometer, so I was happy to be anywhere the ballpark there. I have a bad time with Shars mikes. I bought Starrett outside mikes, but not one for threads.
So I will cut a 9/16-20 male thread tomorrow with an eye on this taper situation. I will start by turning some large round stock to get some exact measurements for the extent of the taper.
