- Sep 28, 2013
- 4,319
1xD is a good rule of thumb for slotting. So two 0.25" DOC passes then one 0.1" pass (clearing chips gets harder the deeper you go), leaving 25 thou for a finishing pass on the bottom. I usually aim for 10-20 thou left for finishing on the walls of slots. I also use kerosene for cutting alu, works as well as WD40 but costs considerably less. Doesn't smell as nice though
If you want to chain drill, use a drill. You can plunge cut with a center cutting endmill, but it's no where near as easy/ efficient as using a drill.
