- Feb 8, 2014
- 11,145
Striatech called me back. It's as expected, no interface to externally control their motor. However, they are working on it for their future controller. With some custom mods, they may have something I can do now but they have to talk to their engineers before getting back to me again.
I guess it depends on your budget. Most likely the least cost and easiest method is a standard 3 phase motor and a sensorless vector VFD. The 3 phase motor/VFD combo will give you a wide speed range, using the lathe gearbox for the course speed adjustment and then use the VFD for the fine speed adjustment. On that machine I would not increase the motor size too much, maybe up to 1.5kW (2HP). If you want to go top shelf, then a servo motor would be a good choice.While I'm going with the single phase on the PM-1236T to start I still plan to keep my eyes open for an "easy" way to put a variable speed motor on it. Ha, easy.... after hours of research and lots of questions . Everything is easy... once you understand it and have done it once.
Having said that, the stock 3HP, 3 phase motor and static phase converter + the lathe gear box (8 speeds, 72 to 2000 RPM) has given me all the range I have needed for about 30 years. I thought about putting a VFD on the machine, but I just haven't figured out a good reason to do so.
This is certainly possible if you put enough motor on the machine. My CNC lathe has a 7.5kW (10HP) servo motor direct driving the spindle at 1:1, about the same torque capability of a small auto engine, but I think a motor that large would twist your lathe into a pretzel. It will run 0 to 3000 RPM. I replaced the original 7.5kW spindle motor (0 to 5000 RPM) with the servo so I could have a C axis for making some parts, I lost 2000 RPM in the process, but nearly doubled the torque. I rarely run it over 2500 RPM anyway.Seems like with all the variable speed motors out there, why not do away with the gear box, just a low/high pulley set and do the rest from a motor that has torque through the range... out of the box of course .
On my manual lathe (13x40), most turning is done at < 500 RPM no matter the material. Maximum spindle speed is 2000 RPM and I only use that with collets when working on tiny parts. Don't worry about the speed charts, they are geared for production work, using flood coolant, and under ideal conditions. On my CNC lathe I generally turn aluminum at about 400 FPM, and SS in the 300 FPM range, but normally keep the spindle speed below 1800 RPM in all cases.Based on RPM calculators, turning 1" aluminum stock, I should be around 500 SFM which calculates out to 1900 RPM, double that for .5" stock. The PM-1236T only goes to 1800. Though, on my atlas 618, I max out at 1500 RPM and can get a decent finish... so, for the newbie, it's hard to know where to start. Seems like most lathes top out around 2000 RPM. Do people actually turn at 2000-4000 rpm?
My brain is just hurting from trying to nail down what lathe, motor combo, electronics if I go the VFD route eventually, DRO choices, so many particulars.
