Also what Brino said- you didn't accidentally bump the stop switch or joggle the protective cover switch? Having a sudden failure like that seems suspiciously like an operator-caused effect
If you have the 7x10 with safety interlocks one of them could cause the problem. Also I had a similar problem and found the speed potentiometer had a switch on the bottom that had broken causing the problem. LMS has schematics for the HF 7x10.
If I remember right, behind the speed control potentiometer is the safety switch, it might not have reset when lathe was overloaded.
I had some notes somewhere on this, not sure where they come from, I have more notes just need to find them somewhere..
If you cant get it going I will search for my notes for you..
I found some more notes and all it says is to jump between terminal 3 and 5 to bypass interlock that will not reset..
sorry this is all I have
Hope I'm not making more work for you, I see that these lathes have change alot in the years they were made.. and not sure the info I have is for yours.
not sure but I think the pot has a resistor to be checked on the back,,,
